Mga bro's, tanong ko lang kung maynapansin kayong kakaiba when using nitrogen gas para sa tires nyo? Baka may alam kayo regarding this stuff.. thanks
The pressure is much more constant; you need not put air as often. The ride is also nicer due to air more evenly distributed.
great ride! :D im rolling on 215/40's it made my ride really better than just ordinary air
Sa Mega Motion sa Banawe ba pure nitrogen ba nilalagay nila pag nagpakarga ka?
After inflating my tires with Nitrogen using my digital pressure gauge sabi 32psi,,
but the next morning eh bagsak sa 28-29 psi yung digital gauge ko.
SO I want to know if pure nitro nila sa mega motion or sira digital gauge ko? dont have other pressure gauge to check.
BR,
epic
You mean mag leak four tires ko ng sabay?
all my four tires have same presuure of 32 after nitro charging, then next morning all was down to 28-29 psi.
BR,
epic
sir,
suggestion po. have ur tire pressure check sa shell stations kasi digital din sila at pwede mo compare ang figures sa monitor mo with that of shell's.
Minerva Tire Gallery in Alabang. I think it's also available in Tire Boy in QC.
I forgot where I read it pero meron din daw sa may The Fort's Bridgestone shop. Unconfirmed pa 'to ;-)
ndi ba delikado ang nitrogen?! ano nga bng qualities nito... hmm hula lng i think mas mataas ang cpacity sa hi temp?
bridgestone, the fort and tireboy, qc ;)
sa bridgestone 100 per tire (sedan)..sa tireboy 75 per tire (sedan)
I always thought it was a scam. If you detest reading long scientific journals, watch this instead.
https://youtu.be/bCnWvMleVD0
someone already said it here.
just keep using ordinary air to inflate your tyres.
if it is true that oxygen (21% of air) seeps thru rubber faster than nitrogen (78% of air),
over a period of time, your nitrogen level inside the tyre gets higher, as the oxygen seeps out faster than nitrogen.
eventually, after several tyre re-inflations, you will have a very high concentration of nitrogen in your tyres.
